Displays the configuration and usage information for MPLS RSVP-TE routed paths.
| path_name | Displays configuration and usage information for the specified MPLS RSVP-TE path. |
| detail | Displays the path information in verbose format. |
N/A.
Specifying the optional detail keyword displays the path information in verbose format. If detail is specified, all LSPs that are configured to use the path are also displayed.
The following example displays configuration and status information for the MPLS RSVP-TE paths:
# show mpls rs path Path Name #LSP #ERO Ord# ERO IP Netmask Type Inc/Exc ----------------- ---- ---- ----- -------------------- ------ ------- path1 1 1 100 9.50.1.2/32 strict include path2 1 1 100 9.50.1.2/32 n/a exclude
The following example displays configuration and status information for the MPLS RSVP-TE paths in the verbose format:
# show mpls rs path det
Path Name : path1
    Hop List Index       : 1
    Path Option Index    : 1
    #ERO/Hops            : 1
    #LSP References      : 1
    ERO                  : Order# IpAddress/Mask     Type   Inc/Exc
                         :    100 9.50.1.2/32        strict include
Path Name : path2
    Hop List Index       : 2
    #ERO/Hops            : 1
    #LSP References      : 1
                         :    100 9.50.1.2/32        n/a    exclude
    This command was first available in ExtremeXOS 11.6.
The output was modified to include the include/exclude information in ExtremeXOS 15.7.1.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
